Quote Originally Posted by pctower
I wonder if anyone remembers "Jack's Secret Sauce" from Jack In The Box' early days in the late '50s. Perhaps some cable company acquired Jack's secret recipe and that's what they are really stuffing inside those mysterious black boxes.
Whatever is those boxes (and a passive one at that) will probably do more damage than not. Electrically, the best signal transfer is the one with least component in its way.
By the way, did anybody find out what was in the Jack's secret sauce
The "problemo" is that many like to go by the catch phrase "all cables [missing part] sound the same" but conveniently disregard the all important [missing part] that qualifies this, which is "of similar length, guage and construction".
Very true. I hope PCtower add that line next time he accuse AR memebers of not hearing difference between cables or components
They [cables] should be compared to an ideal shunt, as close to one as you can get, or put in a circuit which includes a duplicate shunt.
That might be harder than it sound, especially for run-the-mill consumers. How would you create a shunt?
Quote Originally Posted by mtrycrafts
Greenhill already demonstrated that some cables do sound different and it is not a mistery why.
So the line I have seen you use alot such as:"nobody in the world been able to demonstrated differences between cables" is not true any more. Wouldn't you say?
Ribbon cables have very high capacitance and very low inductance.
Not according to Audioholic's speaker cable face-off article. Gene mentioned that Ribbon cables had the lowest measured capacitance out of all the cables in this face off, at the expense of high inductance. Here is the link
http://www.audioholics.com/techtips/...eFaceoffp2.htm
Quote Originally Posted by beckman
So why spend large sums of money on what is basicly a passive crossover when one could purchase an equalizer for $50 on ebay and have an active crossover?
I raised that question a while back in CA, and everybody jump down my throat saying that EQ will add distortion. Little do they realize that passive cables will manipulate the signal more than active component such as EQ does. And the worst part is that if cables doesn't work out for you, you can not change its setting
