Results 1 to 25 of 73
    Quote Originally Posted by okiemax
    Equalizers are practically being given away at eBay auctions. I see auctions for these things starting at $1 and ending up with no bids, and those that do sell, frequently go for prices that are lower than their shipping costs. Depreciation from the price when new may be the worst of any audio gear. Do you have any thoughts on the lack of demand for used equalizers?
    Check out this paper starting on page 16:
    http://international.infinitysystems...rt_science.pdf
    and this:
    http://www.jblpro.com/LSR/PDF/White%20Papers.pdf
    and especially this:
    http://articles.findarticles.com/p/a...ec/ai_70035922
    Sep 2003
    Quote Originally Posted by pctower
    and this:
    After reading these articles, I think I see why equalizers are so cheap on eBay. My guess is many users are disappointed with results from these devices, and may see them as a hifi liability. After looking at several on eBay, however, I can see how the meter readers might go ga ga over these things. A person could spend many pleasureable evenings making adjustment after adjustment to all those controls.
    I have to confess, the gadget lover in me was attracted to a couple of remote-controlled equalizers on auction, particularily a Sansui with a remote that could be hidden inside the cabinet ( at $50 "Buy Now," but no takers). This unit might be worth $30 to me, considering it's entertainment value, and how it would impress my non-audiophile friends, who don't even notice my cables.
    P.S. If I end up buying one of these things, I think it's only fair that I send Beckman the bill for having brought up the subject.
    Nueva Jork
    "...A person could spend...
    ...many pleasureable evenings making adjustment after adjustment to all those controls..."
    Probably one of the misconceived reasons for purchase and why EQs have a low rep...
    For the most part, and when used as intended, EQs should be a "set it and forget it" component...even octave equalizers are difficult, if not impossible to set up by ear. Using program material further complicates the task...A calibrated source, such as a test disk or disc(media dependent) and an SPL meter are the minimal required tools. I've found graph paper, not just a little patience and an understanding spouse to also be invaluable. One must keep in mind, they do have limits and should be used judiciously, functioning as a frequency "equalizer" and not a "gain device"...
    Not that just "playing around" with 'em can't be useful however...it will give you some idea of the level of malarkey that abounds in "audiophile land" re: air and inner details and such...
    If you want to tweak a poor recording, simple tone controls are usually more than sufficient...that's of course if you have any!
    jimHJJ(...worked for me...)
    Last edited by Resident Loser; 05-26-2004 at 11:22 AM. Reason: " i before e except after c" dummy!
    Feb 2003
    How about you send me a check for the price difference between an equalizer on ebay and a high end set of speaker cables
    Jul 2002
    As for two channel audiophile's I think they look down upon anything that alters the sound of the music by attenuating the signal for a certain frequency range. I personaly have an integrated amplifier that does not have any equalizer controls on it and don't find that it needs them.
    I have news for audiophiles, your room already alters the sound of the music. Has anyone here heard of a mode or a node? Resonances?
    Eq is a VERY valuable tool in the hands of the educated and experienced. It in combination with acoustical eq(bass traps, absorption foam, diffusor and reflectors) can transform a really bad sounding room, into one that has quite please sonic qualities. Of course CHEAP eq's don't help in any situation. One octave eq's are less than worthless.
    Not many people know what to look for when purchasing a EQ, so off to ebay. Most purchase cheap, usless eq's, so off to ebay. Most do not have the associated equipment that it takes to even make a very good eq helpful, so off to ebay.
    Eq is not the problem, ignorance, inexperience, and lack of education are.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Feb 2003
    Just out of curiosity, where are these good eq's. It seems like there are a ton of really cheap ones out there. I know McIntosh makes some, but are there others?
    As for having the associated equipment to make a good eq helpful, why couldn't a good eq be helpful to any stereo?
    I am not looking for an argument, but posing serious questions
    F1
    F1 is offline
    Forum Regular F1's Avatar
    May 2003
    Quote Originally Posted by Beckman
    Well I'm happy with Behringer FB1502 15-band equaliser. It's only $120 which is much cheaper than those exotic cables.
    JBL Whore Bobby Blacklight's Avatar
    New York
    Hello Beckman
    There are a couple of nice EQ's I can think of being Urei 539 and White Instruments. 1/3 octave cut only. Low noise very nice units. Then you have parametrics with give you more flexabillity. But you have to know who to use them.
    Nov 2002
    Unlike either you or skeptic, I have found it to be a trivial matter to setup and use my two channel 11 band eq.. Trivial enough, in fact, that my 9 and 11 year old children can also use it..
    It is, of course, unfortunate, that once I have touched those damn knobs, I eventually have to bypass the stupid thing to get any reaonable sound out of it..
    The only reason I have the darn thing is to eq the daylights outta my mobile two way rig..I designed the speakers for portability, efficiency, and spl...using 5% crossover components, and going for a simple +/- 3db on axis response..yah, the sweet spot (if there really is one) is about two degrees wide...but 450 people don't complain..(true, I wouldn't listen anyway...he he).
    Cheers, John
    PS..yah, I really do agree with you...an eq in the hands of some is a weapon of masked destruction..
    "I have found it to be a trivial matter to setup and use my two channel 11 band eq.. Trivial enough, in fact, that my 9 and 11 year old children can also use it.."
    Apparantly that is why you get results that are so trivial that you prefer to bypass it. I think that proves my point. Even if you suspend your disbelief that this can actually be a useful tool in a fine home audio system, getting real benefit from it takes more than a trivial effort. Most people give up long before they even start down the right road so what you say is hardly surprising to me.
    If you ever decide to make any serious attempt to use it. Why not first listen to a lot of unamplified live music, then set all of the controls for flat, and then adjusting only one or two controls very cautiously, see if you can get just a minor improvement for a start. Don't do anything else for weeks until you are convinced that the change is for the better not for the worse. Then satisfy yourself with just a small improvement each time taking days or weeks to decide if the last change was for the better or the worse. Reitterate this until you are just about nuts and you'll get some idea of why I say it is a long slow patient process. Any attempt to fix every problem at once is doomed.
    Nov 2002
    Ummm...Skep? Ya gotta lighten up, dude..it was a joke..don't worry, I'll keep my day job..
    Cheers, John
    Nueva Jork
    Well...
    ...I have no idea why equalizers don't seem to have a market...perhaps, most of them are cheaply-made, with the ability to screw things up more than fix them...less than octave-width, which really renders them glorified tone controls...misunderstanding their abilities and incorrect use by consumers may also have given them a bad rap...outright misuse is fairly common; it would seem as though most users employ them as overall "gain devices" as opposed to equalizers...
    Now for the fun part...PCT, I'm not sure what sort of follow-up research you did re: your citations but, after reading them, off went all my buzzers and bells...the first two "white papers" were authored by people who would seem to have more than a passing interest in their respective organizations proprietary ideas and products. Both schemes seem aimed at the professional market and perhaps, at some future date, may filter down to the home audio enthusiast in a reasonable and reasonably priced form.
    The co-authors of the third reference are even more firmly entrenched in the marketing facet of the industry...one of them seems to have been, at various times: an electronic publisher, a media company director and even the editor and webmaster of the site cited itself(say THAT a few times)...other titles include: sales manager, manufacturers rep, marketing manager and director of sales. The other was named director of business development of a well-known name in pro audio apps, has held other "key sales and marketing positions", was VP of sales and marketing for another. regional sales manager and manufacturers rep for yet another.
    Hardly trying to denigrate these gentlemen's abilities in their respective fields of expertise, but I always have to take what certain folks say with a grain of salt...especially when they all seem to badmouth one thing in deference to something else they seem to have...er, shall we say...an "interest" in...
    jimHJJ(...but, of course and as always, that's just me...)
    Dr. Toole is God on this board. You are risking excommunication.
    Nueva Jork
    He ain't mine...
    ...I just calls 'em as I sees 'em...let the chips fall where they may...
    jimHJJ(...I guess that's why I'm still doin' what I have been for 35 years...)
  1. The Great Cable Debate
    By happy ears in forum Cables
  2. bi-wiring
