Quote Originally Posted by Tony_Montana
Whatever is those boxes (and a passive one at that) will probably do more damage than not. Electrically, the best signal transfer is the one with least component in its way.
By the way, did anybody find out what was in the Jack's secret sauce
Very true. I hope PCtower add that line next time he accuse AR memebers of not hearing difference between cables or components
That might be harder than it sound, especially for run-the-mill consumers. How would you create a shunt?
So the line I have seen you use alot such as:"nobody in the world been able to demonstrated differences between cables" is not true any more. Wouldn't you say?
Not according to Audioholic's speaker cable face-off article. Gene mentioned that Ribbon cables had the lowest measured capacitance out of all the cables in this face off, at the expense of high inductance. Here is the link
http://www.audioholics.com/techtips/...eFaceoffp2.htm
I raised that question a while back in CA, and everybody jump down my throat saying that EQ will add distortion. Little do they realize that passive cables will manipulate the signal more than active component such as EQ does. And the worst part is that if cables doesn't work out for you, you can not change its setting
Just to keep the record straight, I'll bet if someone could go back through all the old archives of AR and AA for the past 2 years for purposes of seeing who used the phrase "of similar length, guage and construction" the most they would find that I've used it more than everyone else combined.
