Results 1 to 25 of 73
    Jul 2002
    As for two channel audiophile's I think they look down upon anything that alters the sound of the music by attenuating the signal for a certain frequency range. I personaly have an integrated amplifier that does not have any equalizer controls on it and don't find that it needs them.
    I have news for audiophiles, your room already alters the sound of the music. Has anyone here heard of a mode or a node? Resonances?
    Eq is a VERY valuable tool in the hands of the educated and experienced. It in combination with acoustical eq(bass traps, absorption foam, diffusor and reflectors) can transform a really bad sounding room, into one that has quite please sonic qualities. Of course CHEAP eq's don't help in any situation. One octave eq's are less than worthless.
    Not many people know what to look for when purchasing a EQ, so off to ebay. Most purchase cheap, usless eq's, so off to ebay. Most do not have the associated equipment that it takes to even make a very good eq helpful, so off to ebay.
    Eq is not the problem, ignorance, inexperience, and lack of education are.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Feb 2003
    Just out of curiosity, where are these good eq's. It seems like there are a ton of really cheap ones out there. I know McIntosh makes some, but are there others?
    As for having the associated equipment to make a good eq helpful, why couldn't a good eq be helpful to any stereo?
    I am not looking for an argument, but posing serious questions
    F1
    F1 is offline
    Forum Regular F1's Avatar
    May 2003
    Quote Originally Posted by Beckman
    Well I'm happy with Behringer FB1502 15-band equaliser. It's only $120 which is much cheaper than those exotic cables.
    JBL Whore Bobby Blacklight's Avatar
    New York
    Hello Beckman
    There are a couple of nice EQ's I can think of being Urei 539 and White Instruments. 1/3 octave cut only. Low noise very nice units. Then you have parametrics with give you more flexabillity. But you have to know who to use them.
    Nov 2002
    Unlike either you or skeptic, I have found it to be a trivial matter to setup and use my two channel 11 band eq.. Trivial enough, in fact, that my 9 and 11 year old children can also use it..
    It is, of course, unfortunate, that once I have touched those damn knobs, I eventually have to bypass the stupid thing to get any reaonable sound out of it..
    The only reason I have the darn thing is to eq the daylights outta my mobile two way rig..I designed the speakers for portability, efficiency, and spl...using 5% crossover components, and going for a simple +/- 3db on axis response..yah, the sweet spot (if there really is one) is about two degrees wide...but 450 people don't complain..(true, I wouldn't listen anyway...he he).
    Cheers, John
    PS..yah, I really do agree with you...an eq in the hands of some is a weapon of masked destruction..
    "I have found it to be a trivial matter to setup and use my two channel 11 band eq.. Trivial enough, in fact, that my 9 and 11 year old children can also use it.."
    Apparantly that is why you get results that are so trivial that you prefer to bypass it. I think that proves my point. Even if you suspend your disbelief that this can actually be a useful tool in a fine home audio system, getting real benefit from it takes more than a trivial effort. Most people give up long before they even start down the right road so what you say is hardly surprising to me.
    If you ever decide to make any serious attempt to use it. Why not first listen to a lot of unamplified live music, then set all of the controls for flat, and then adjusting only one or two controls very cautiously, see if you can get just a minor improvement for a start. Don't do anything else for weeks until you are convinced that the change is for the better not for the worse. Then satisfy yourself with just a small improvement each time taking days or weeks to decide if the last change was for the better or the worse. Reitterate this until you are just about nuts and you'll get some idea of why I say it is a long slow patient process. Any attempt to fix every problem at once is doomed.
    Nov 2002
    Ummm...Skep? Ya gotta lighten up, dude..it was a joke..don't worry, I'll keep my day job..
    Cheers, John
  1. The Great Cable Debate
    By happy ears in forum Cables
  2. bi-wiring
