I pointed out on another thread that comparing cables to each other makes no sense at all and all such tests are invalid. They should be compared to an ideal shunt, as close to one as you can get, or put in a circuit which includes a duplicate shunt. The difference between the cable and the shunt is the magnitude and nature of the distortion of the cable. It should be pointed out that the same cable can give different results when being connected to different equipment. Therefore recommendations based on the results in one sound system may not be relevant to the results you would get with a different sound system.
