So the line I have seen you use alot such as:"nobody in the world been able to demonstrated differences between cables" is not true any more. Wouldn't you say?
No, not at all, I would not sat that. The 24 ga speaker cable in that test is not considerd to be a product that qualifies as a speaker cable. Broken.
16ga or better are. Try that on.
Not according to Audioholic's speaker cable face-off article. Gene mentioned that Ribbon cables had the lowest measured capacitance out of all the cables in this face off, at the expense of high inductance. Here is the link
http://www.audioholics.com/techtips/...eFaceoffp2.htm
Well, please check out this link:
http://bruce.coppola.name/audio/cableInteractions.pdf
Check out what cable 6 and 11 are as identified on page 2 as and then check out in figure 2 on page 3 as to which cable has the most capacitance. How about cable 6 and 11? Oh, he identifies them as ribbon cable?
Maybe ribbon cables changed over the years? Please note that this is a peer AES journal paper
