Results 1 to 25 of 136
Like Tree51Likes
    So why do people feel that differences cannot be heard now unless the room is optimized. First we had "There cannot be any difference" then we get "I can hear subtle differences" and then "nobody can hear differences unless the room is treated".
    I know a well treated room sounds better than a non-treated room, but if the only thing being changed in the system is the cable, and whatever room it is stays static, then there is no reason the same or similar differences cannot be heard in a non-treated room. If the room was treated, the differences may be more profound and easier to hear, but I disagree that one needs a fully treated room to notice a difference in some cables, maybe not all.
    Jul 2002
    Since I alway knew you could not read, I expected this kind of response. I never said there could not be any difference, I said that the differences ARE TOO SMALL to make such a big deal. I also said with all of the noise of a typical living room(ambient level) it would be pretty damn difficult to hear the differences, and when you combine that with poor acoustics, you really cannot be sure what you are hearing.
    Going into the "science" of why I think your claims are bogus would be futile. Since I can see you know nothing about the science of anything(my ears tell me everything mentality), then going into detail about why I think you are hearing things would be a waste of breath.
    Thank you for making my point about your lack of scientific knowledge - especially when it comes to audio. It is not just about treating the room, that is another layer of performance enhancement. It is also about eliminating ambient noise so you can truly detect subtleties and nuances which make up the differences between good cable designs, and the lesser designs. Cables should never sound "dark" or "bright" as some of you insist. Cables should be neutral of any sonic character, and the best cables are very revealing of nuances and subtleties - things that cannot be heard on a mediocre system, in a room with resonance and modal ringing, and with ambient levels so high it buries the those details.
    Sighted tests are useless, and this link tells exactly why I believe this;
    Audio Musings by Sean Olive: The Dishonesty of Sighted Listening Tests
    This might be too much science for you, but give it a try. You just(and I mean JUST) might learn something for a change.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
