Results 1 to 25 of 136
Like Tree51Likes
    Quote Originally Posted by Smokey View Post
    But fine tuning the sound is not function of cable. That will remain true whether we have low end or high end system
    But cables do tune a system. So if you buy a cable that makes your system sound bright you should just live with it? I would find a cable that makes my system sound balanced. Which I call tuning the system. I also find purchasing a new cable if the sound is bright than buying dark sounding amp just to use the much less expensive IC.
    blackraven likes this.
    Suspended Smokey's Avatar
    Ozarks
    I would say that be a common sense approach assuming that all the audio (and sources) played on that system have same 'audio' quality and EQ biasing.
    But since that will not be the case (as even each recordings have different EQ), then we should wonder as how cable is effecting different sound quaity. And we could never could figure that out if we are using cable to tame our system.
    So the problem of cable as part of a puzzle to achieve more balance system will never be solved
    Of course I disagree. With my choice of AQ IC's and speaker cables they let all the music present itself wonderfully with my selection of components and speakers.
    3db
    3db is offline
    Jan 1970
    Cables don't tune a system nearly as much as does seating position within the room and the room's acoustics. Most people in gross error try to go to tune using cables and interconnects then to fix the seating position and the room's acoustics. Cables/interconnects are sooo far down the affects list yet so many people in error put so much weight on them. I find this strangely amusing.
    Some people have done all they can do to their rooms and the way seating is setup. Not everyone is fortunate enough to have a dedicated listening room where they can set all that up optimally so what is left? Tweaks and Cables.
    JohnMichael and blackraven like this.
    3db
    3db is offline
    Jan 1970
    My point is that the effects of interconnects and cables on sound are so low compared to everything else that one will not get results they are looking for by cables and interconnects. The analogy I draw is one trying to make an oar out of log using 220 grit sandpaper. Its just not going to happen.
    Worked fine for me in one application and seems to work for the many I associate with on several other sites. I am not sure what your gear is, or what cables you have rolled, but my gear resolves some cable differences and so does the systems of others in this thread. If I have a known bright system, and I put a know bassy cable in place and I like the sound it gives me, all the theory goes out the window.
    3db
    3db is offline
    Jan 1970
    I can't throw theory aside as its theory that built audio in the first place. I'm also not going down the "your equipment isnt revolving enough to be able to tell differences in cables/interconnects" when I know full well that my room as of yet is not acoustically perfect. I'd rather throw my money on things such as acoustic treatments that will fix the issues based on theory than fixes based on subjective results that can be replicated by theory.
    That is perfectly understood, but I again pose the question as to what do you do if you have exhausted efforts on the former? I cannot put a bunch of absorbers on my living room walls, I don't have a dedicated room I can arrange and treat as desired so I have to work with what I am left with. If a $50 pair of ICs does the trick for me, who is anyone to say it's wrong?
    I would love to have a dedicated room built just for sound, but it ain't gonna happen for me unless god forbid I end up a widower at an early age. If you have that room, great, I hope you can tweak it with thousands of dollars of Bass Traps and Panels instead of a cheap pair of ICs.
    So if cables are out of the question as tone controls, are Tone Controls OK to engage?
    If yes, what do I do with units that do not have tone controls in the signal the path?
    3db
    3db is offline
    Jan 1970
    If tone controls make the sound more appealing to you, by all means go and do that. Audiophile purists poo-poo the idea but who cares what they think. As long as it makes things more palatable for you in your listening environment, then go for it.
    Your analogy isn't correct, more like whether you have a Civic or Porsche you can choose to drive on donuts or expensive Michelan, both the donut or Michelan will get the vehicle down the road but one will do a much better job while the other has limitations. Most audiophiles I know with reasonable quality gear who have actually compared cables agree there are not only differences in sound but improvements to be had. And, you do have to compare, there are so many cable companies popping up out of the woodwork these days.
    I've treated my room with curtains & tapestry which help. I have a friend who has spent a lot of money of room treatments and to me his room is too dead sounding, I like the 50/50 approach, not too dead or live. But, even treating a room is subjective unless you have a spectrum analyser and the knowledge to find the correct treatment for the problem that may be found.
    I'm not saying any one else's approach is wrong but for me the cables should be an overall improvement in the sound, better resolution, detail etc. I've not purchased any cables with a "fix" to my system in mind. Nay sayers there will always be but these cable companies are able to voice cables, that's why it's possible to use them to tailor your system to sound a bit warmer or extended etc. I like cables who have a rep for being neutral but that's even a moving target as who knows what "neutral" should really be. Audio is like the 60's man, if it feels good, or in the case of audio, sounds good, DO IT
    JohnMichael likes this.
    Mr P, I prefer a live room. I like the music hall effect.
    Concerning tone controls, I prefer to have them. After playing around with the tone controls on a Mac preamp a few months ago, I am convinced that they would be great to have. For bright music, just turn the treble down a bit and bump up the bass and things sound much better.
    Ozarks
    For those who "listen" to cables might not know what "neutral" cables should be or sound like, but there alot of professionals in audio world that their cables should be neutral or transparent.
    Poeple like musicians, studio engineers or record producers (or those who seek "true to source" sound) seek a neutral cables so they can tune or calibrate their equipments. And I let you guess how those poeple choose their cables
    3db
    3db is offline
    Jan 1970
    If these findings were based in an uncontrolled environment with knowledge of which cables/interconnects were being used, then too much bias from the other senses would have interfered with the listening and skewed the results. Anyone claiming that cables/interconnects has more influence on sound than speakers, room acoustics, and the listening position with respect to room/speakers doesn't should take some time to read Dr Floyd Tool's work in audio and the human perception of hearing and the influence of the other senses on hearing.
    Jul 2002
    How can anyone possibly hear any differences between anything in a non-optimized room? They can't, hence my skepticism on this topic coming from these sources.
    Sometimes all you can do is not always good enough.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Jul 2002
    Cables do not tune a system, and if one understands the function of cables they could not make this claim. If a cable sounds bright, get rid of it. If the cable sounds neutral and revealing, keep it. If you are interested in bright or dark sound(or anything in between), add EQ or add or remove acoustical panels, not cables.
    Tuning requires a function of control...cables offer no controls which makes them to crude and unsuitable for tuning. Adapting the speakers to the room requires EQ and acoustical panels which do have controls.
    Sir Terrence
    Oppo BDP-103D
