Results 1 to 25 of 136
Like Tree51Likes
    Suspended Smokey's Avatar
    Ozarks
    I like cables who have a rep for being neutral but that's even a moving target as who knows what "neutral" should really be.
    For those who "listen" to cables might not know what "neutral" cables should be or sound like, but there alot of professionals in audio world that their cables should be neutral or transparent.
    Poeple like musicians, studio engineers or record producers (or those who seek "true to source" sound) seek a neutral cables so they can tune or calibrate their equipments. And I let you guess how those poeple choose their cables
    Sir T said, "The cables I chose sounded as neutral, uncolored, and transparent as a live voice going through a microphone, through the straight wire busses of my mixing" etc.
    I think we'd all be interested in knowing which cables a hotdogger like yourself uses.
    You are surprisingly off base on this topic by a long shot.
    3db
    3db is offline
    Jan 1970
    Subjective results are irrefutable to only that listener claiming the results. However, these same results are also non admissible as concrete evidence to the rest of the world because the tests are most likely conducted under sighted conditions. These subjective tests are also flawed based because the tests aren't configured for instantaneous swapping on cables thus relying on audible memory which Dr Floyd Toole prooved to be inaccurate at best and is required to remember the subtle nuances that different cables are purported to produce. I'm sorry buts its all snake oil and the audiophiles are slathering this oil on like sun screen.
    Ozarks
    I'm not familiar with Dr Floyd's writings, but I agree. For valid results that everybody can agree on, the memory factor have to be taken out of equation.
    With memory factor out, then it doesn't matter if test (instantaneous swapping) is sighted or unsighted. The results will be the same
    I made an important discovery this morning. My stereo is much more musical and enjoyable with cables than it is without. It seems cables in a system makes it more communicative. I did not need to DBT this since it was so readily apparent.
    Mr Peabody likes this.
    No kidding, there's no way I could go back to generic cables, if the disbelievers couldn't hear that difference there should be an appointment made to check hearing.
    Jul 2002
    Sorry, not a hotdogger. I hate hot dogs.
    Right, and you are on base. The claims you make have yet to be proven, and your subjective experience just doesn't cut it as proof. Sorry......
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Jul 2002
    If what Sir T says is true he wouldn't even need speakers, just a bank of test equipment. Who needs to hear to be an AUDIO engineer, we just measure. The bottomline no matter what they say they still use their ears at some point for subjective listening. And subjective listening is just as effective in a studio as in a living room as on the beach tunig an acoustic guitar.
    Mr. Peabody, either you cannot read, or you have not been reading what I post. I said pretty clearly that I listen first, and then correlate what I hear to what I measure. There is no point in measuring if you don't listen to WHAT you measure. Much like there is no point in just listening subjectively without measurements to correlate what you hear.
    Any claim that listening in a living room contaminated with high ambient noise levels and poor acoustics is as good as listening in a studio with tightly controlled acoustics and NO audible ambient noise has obviously never been in a quality studio in their life.
    Pretty hard to make that claim with no reference whatsoever.
    Sir Terrence
    Oppo BDP-103D
