Quote Originally Posted by okiemax
Yes, but equalizers are a lot of trouble to use right, and room treatments and optimal speaker placement may be objectionabe to other family members. Cables are easy to switch in and out, and aren't conspicious. Neither way guarantees satisfaction, but the cables likely come with a money-back guarantee, while room treatments and the expense of professional help(if needed) with the equalizer may not. Then there is the issue of the equalizer coloring or distorting the sound even if it is set up properly, which keeps some audiophiles from using these devices.
Equalizers can be used to tailor sound in a way that will more pleasing. This thread has assumed all audiophile cables are designed to tailor the sound. Is the assumption true?
Equalizer like the ones from Behringer have spectrum analyser LED on the slider itself so you can address the problematic frequency without SPL meter even though it won't be as precise but not too far off. You can find baseline setting more easily.
BTW what is the audiophile's objective to use audiophile cable?
