Quote Originally Posted by barbarian
When considering a new cartridge; which path do you guys recommend? The Ortofon OMB-10 sounds good because of the upgradable stylus. Any other suggestions?
There's a short list of popular budget carts. Noob had the Nag and the Shure, and I had a Ortofon. You can also add the Ortofon 2M Red. I am actually re-recommending this to you. The 2M series is also upgradable, with the Red being the entry level. The better your table or arm gets, you can upgrade the stylus. I have a 2M Red and they're great value. Since you saved a little with the speakers, splurge a bit more on the cart. They're 99.99 at Needle Doc....wife is yelling, bye....
