Quote Originally Posted by barbarian
I'll look into making/buying some sort of wall mount. This is probably the best solution.
Are these wires okay; is it necessary to get a more expensive set? I really don't know what I should look for in speaker wires: http://www.radioshack.com/product/in...ductId=2102499
Thanks for all the tips. You guys really rock!
as audionoob suggested, a simple cable will work for now, (the ones you can find at radioshack), the one you suggested, however, I would not take, go for 14 or 16 gauge, probably 16 gauge, as any bigger might be to thick for the marantz to hold firmly. you could install banana plugs on the speakers end for easier connection, and avoiding oxidation.
http://www.radioshack.com/product/in...uctId=2104178# this, for instance, should work pretty good, I use flex plugs at the receiver end here (a vintage Luxman R-800), this allows me to use thicker cable (I only had 10 gauge cable lying around...)
Have fun
Keep them spinning!
Bert.
