I have an equalizer question! I see that there are equalizer that start form 30 frequency, from 31, 31.5 and most of the time 32! Is it true that the lower the number the better?
Here is another question! Is it good to connect 2 equalizers one after another?
if you're gonna go with two equilizers one after the other you're gonna need an amp with a preamp in the back of it.with your pre out and main in inputs.do not try to hook it up through you tape monitor inputs.you'l need to go out from your amp from your pre out into your first eq main in,then from the pre out of eq #1 to the main in of eq #2 then pre out of eq #2 back to the main in on your amp. it will work but if you want to do it but i'd recomend hooking up a reverb wth an eq instead of two eqs.
