Results 1 to 25 of 56
    Chicago IL
    Jul 2009
    Chicago ,IL
    Thanks for all the answers! Thats why we are here to help each other!
    I have everything kenwood home and I see that the best equalizer is GE-1100
    What do you guys think, is it good to get them or not?
    Listener MikeyBC's Avatar
    Feb 2004
    Northern Ontario
    How are you seeing the best is the GE-1100 ? by the low number? 16 hz? Id avoid an eq with depth and delay-time controls. It may be alright to EQ a mild peak or a dip here and there but that's it, anything more and your creating more problems
    16 hz is kinda useless for music unless you have a lot of very warped records, then you can cut the lowest frequencies to keep your woofers under control.
    Musical Fidelity A3.2 Integrated amp
    Musical Fidelity A3.2 CD
    Teac DS-H01 Dock
    Energy 22 Reference Connoisseur Speakers
    Cardas Cross and Cardas Hexlink Golden 5C
    Tara Labs RSC Reference Gen2
