Equalizer Question
I have an equalizer question! I see that there are equalizer that start form 30 frequency, from 31, 31.5 and most of the time 32! Is it true that the lower the number the better?
Here is another question! Is it good to connect 2 equalizers one after another?
http://i46.tinypic.com/67p5ef.jpg
Actually its the bandwidth the EQ covers that is most important. The EQ in the picture is a 10 band EQ that is basically too crude to use for anything.
The most common usable EQ is a analog or digital 1/3 octave 30 band EQ, where the first band begins at 20hz.
The better EQ's are digital 1/6, 1/10, 1/20 and 1/30 EQ's which the latter can basically correct most anything. The latter is extremely expensive, and I have not seen a lot of these around.
It is a terrible idea to cascade two EQ's together. The phase issues alone with this setup would be enough to turn anyone off on it.
I will add with what STtT said that using an EQ is something that takes understanding the properties or sound reproduction and what musical information is at different frequencies and using an EQ without having knowledge in how to use it can often lead to unnatural sound that is extremely boosted at the frequency extremes and hollowed out in the midrange. I seen it many times where a person without knowledge of how a EQ can help a system will just do the scoop thing that they have seen others do which in most cases makes the sound of any speaker system unnatural but to it over emphasizes the bass and upper treble so it has a since of better sound to the sound uneducated.
While the apparent picture of the typical *smiley face* settings as illustrated looks smooth, in actuality it would result in a roller coaster of peaks and valleys ending up with a most unnatural sonic result.
Do you understand there are sonic compromises made to the signal integrity in terms of phase and distortion with even one in the path?
Thanks for answering my questions! I was curious because I was using realistic equalizer and I changed it with a teac and the Teac sounded much better and the realistic eq started from 32 and the teac from 30 so thats why I asked!
For connecting one after another I asked because I saw a friend who did that and he had way too much bass but the sound was still clear!
To the OP: Make sure you take care of other problems first such as speaker placement and getting rid of echos inside your room. Then use EQ very last. The less EQ you have to use, the better because of less distortion. Thats why putting 2 together is a bad idea
The best way to EQ is this: Use a parametric equalizer. It lets you specifiy exactly what frequency you want to adjust and the width of the adjustment. Graphic equalizers like your teac only have 10 different pre-determined frequencies. A parametric Equalizer is much more precise.
What you want to do is download a program called SineGen for Windows. Slide the frequencies up and down and listen for frequencies that get suddenly louder. Whatever frequencies get louder, you want to turn down on the EQ. Whatever frequencies are too quiet, raise on the EQ. You want every frequency to sound the same volume level if that makes sense.
It takes patience since the human hearing can hear 20,000 frequencies.
Those numbers correspond to the frequency that you can boost or reduce. Whether that first frequency is 30, 31, 31.5 or 32Hz makes very little difference. Those types of equalizers are more of a gizmo than anything. They most probably do more harm then good. Beside, if you want to be accurate you'll want to work with an SPL meter. A 10 band equaliser, as Sir TtT said, is not going to be able to flatten the whole frequency spectrum.
If you're system is mediocre, there's no harm in using an EQ. If you want something better, leave it out:)
lol, I'm suprised you think you got an answer to that. I don't think anyone understood that part, that's why I've chimed in.
You'd be hard pressed to tell the difference. Here's a single frequency sweep from 30-39 hz. Each frequency lasts ten seconds. Try it out!
Which is what I said no?
Sorry, no full range speakers or subwoofer here:)
Yes. It was intended for the OP to determine for himself. There is also the possibility that he shares the same situation as you.
Thanks for all the answers! Thats why we are here to help each other!
I have everything kenwood home and I see that the best equalizer is GE-1100
What do you guys think, is it good to get them or not?
http://i50.tinypic.com/343jksh.jpg
How are you seeing the best is the GE-1100 ? by the low number? 16 hz? Id avoid an eq with depth and delay-time controls. It may be alright to EQ a mild peak or a dip here and there but that's it, anything more and your creating more problems
16 hz is kinda useless for music unless you have a lot of very warped records, then you can cut the lowest frequencies to keep your woofers under control.
I meant that the best EQ Kenwood has made is the GE-1100! Do you know any better Kenwood EQ ???
Ok, I see. No I don't know of any better Kenwood EQ though I never really looked for one either.
1 Attachment(s)
Ok I looked, the Kenwood GE-7030 would be the one i'd buy if i had to buy a Kenwood...its a parametric.
I have seen the GE-7030 but I never thought they will be better! Well I will start hunting for a good deal!
If you really want a EQ that will really help your system you should try a receiver with Audussey EQ
http://www.audyssey.com/technology/m...solutions.html
In all of my years calibrating home theater systems, this is the most effective system I have ever used by far.
Its a parametric eq which means you can alter the center frequency of each band of the eq...this gives it much more flexibility for frequency correction.
There are better and higher quality eq's out there but if you want to stay all Kenwood this is where I'd go. (GE-7030)
HATE to agree with sir talky about anything, but the Audyssey is a nice system,
even on my (reletively) cheap receiver(1,000$)
Not only does it set the levels but also "eq's" every speaker dynamically, which solves the problem of EQ on a 7.1 system.
Dont have mine on at the moment, preferring my music two channel straight, no chaser,
but the sound is very good with it.:1:
Or a Rane Or an Ashly PEQ...
I picked up an Ashly 572 PEQ a few years ago and it is SUPERB! Each channel has 5 fully parametric bands plus low and hi shelving filters. Quality is excellent and it is a scalpel when it comes to fine tuning. Discontinued now, but can be found on pro audio sites, ebay, etc.
Here it is for $350 on ebay!
http://cgi.ebay.com/Ashly-PQX-572_W0...#ht_500wt_1182
I have never heard of this brand Ashly!
The major problem with the Ashly setup is that it is XLR connected only. That is a problem with the majority of HT equipment out there, even though it is a better connection. You still have to measure the room carefully before using this kind of product. If you don't know what you are doing with this thing, you can make acoustical problems electrical and phase problems as well.
For most folks that do not have the proper measuring equipment, I would advise you to pick a system that does the work for you. The Audussey system only asks that you set up the microphones in the best places for viewing in your room, and it does all of the rest. The results are ear opening to say the least.
go with a soundshaper 2 if you want quallity
if you're gonna go with two equilizers one after the other you're gonna need an amp with a preamp in the back of it.with your pre out and main in inputs.do not try to hook it up through you tape monitor inputs.you'l need to go out from your amp from your pre out into your first eq main in,then from the pre out of eq #1 to the main in of eq #2 then pre out of eq #2 back to the main in on your amp. it will work but if you want to do it but i'd recomend hooking up a reverb wth an eq instead of two eqs.
