Results 1 to 25 of 73
Threaded View
  1. #9
    Sep 2003
    ...a fool's errand IMHO...
    ...as I outlined in my response to your post yesterday...and which I take the liberty of re-posting here:
    ...many pleasureable evenings making adjustment after adjustment to all those controls..."
    Probably one of the misconceived reasons for purchase and why EQs have a low rep...
    For the most part, and when used as intended, EQs should be a "set it and forget it" component...even octave equalizers are difficult, if not impossible to set up by ear. Using program material further complicates the task...A calibrated source, such as a test disk or disc(media dependent) and an SPL meter are the minimal required tools. I've found graph paper, not just a little patience and an understanding spouse to also be invaluable. One must keep in mind, they do have limits and should be used judiciously, functioning as a frequency "equalizer" and not a "gain device"...
    Not that just "playing around" with 'em can't be useful however...it will give you some idea of the level of malarkey that abounds in "audiophile land" re: air and inner details and such...
    If you want to tweak a poor recording, simple tone controls are usually more than sufficient...that's of course if you have any!
    jimHJJ(...worked for me...)
    I think skeptic said he did it by ear. I wasn't sure about everyone's description of what they did, which Is why I prefaced my question with a "I may be missing something."
    Anyway, not having used an equalizer, I'm not sure I understand the procedure. How do you know the equalizer is needed to begin with, if not by using your ears,and how do you know you adjusted the equalizer right, if not by using yours ears? And if you listen, is it blinded or sighted listening?
  1. The Great Cable Debate
    By happy ears in forum Cables
  2. bi-wiring
