Quote Originally Posted by Pat D
Absolutist advice? What is this, Phil, argument by making up a phrase, attaching an adjective to a noun? It looks like another misrepresentation. We do not maintain the null hypothesis is proven, never have, and yet you continue to make the false allegation that we do. You imply that we do not want larger scale studies to increase reliability, to reduce the likelihood of Type II errors, which is false, and you know it. Of course, if one does not conclude the null is proven, then one avoids making Type II errors. None of this deters you, Phil, for you keep on making the same false allegations.
You are referring to Wrightstuff, of course! In any case, mtrycrafts manner is irrelevant to whether interconnects and speaker cables make an audible difference and under what conditions.
The only misrepresentation around here is your mis-characterization of what I have said. When referring to mtrycrafts "absolutist" advice, I did not say or imply that you, mtrycrafts or the Pope don't want better tests. I have never come close to inferring that (although I have raised any number of unanswered questions regarding the test results that are often cited on this board). That was not the subject when I addressed the way in which mtrycrafts give advice. The subject was the advice mtrycrafts gives to newcomers, without any explanation as to how he arrived at his absolutist type advice.
I am not detered by your constant mis-characterization of what I have said in your effort to set up a stawman with whom you can argue. Why don't you show some guts and go over to AA and take on Curl and Reisch like I do.
And of course I never suggested or implied that it does. In your one dimensional world the only subject that can be discussed is DBT's. There are other issues that non-Spock type people are interested in - such as inter-personal communication and attitudes.
