If You Want Better For Cheaper.......................
Dear A/V Friend,
Better for cheaper is easy in my opinion. I had a 13ft pair of Tara Labs Prism Bi-wire cable set up for single run. I paid $180 for the pair 7 years ago. Last month I bought a 100ft. roll of CL rated XPHP from Best Buy (click on link below). I ran a single cable of this stuff to my surrounds and a double run to each of my main speakers and center channel speaker. Of course I used Monster Banana Jacks and Flexi-Pins too. The double run of this cable to my main speakers blew away my $180 Tara Labs Prism Bi-wire. I couldn't believe it! What a difference. Even my wife who doesn't have an audiophile ear could tell a BIG difference. This compact In-wall/Out-of-wall design employs nearly all of the significant technology of the more expensive Monster Cable. I'd bet a double run (i.e. a single cable for ea. "+" and "-") to each Main speaker,of this stuff, would blow your M1.2 away! As for actually bi-wiring your speakers, I think using a double run of speaker cable to each speaker would do just as fine a job as actually bi-wiring them. For $129 for the wire and maybe $100 for 5 sets of jacks you can't go wrong. Oh yea, it'll take you 30 minutes per cable to install the banana jacks to the cable carefully. Also, just so you know how much mark up there is on Monster Cable products, my nephew gets a 60% discount on all Monster Cable products as he is a Best Buy employee. High end stereo stores that sell Monster products have room to deal--believe me! My whole project cost was less than $100 because I knew someone at Best Buy. Best hundred bucks I have ever spent in my life. The sound quality difference was breathtaking. I bet Monster wouldn't like this cheap secret to get out that a double run of their cheaper cable sounds better than a single run of their more expensive stuff. Hope this helps. I can't imagine you could go wrong with this advice. Remember to click the link below so you know exactly what monster cable I'm talking about. There is a cheaper version of this cable that looks similar but uses a smaller gauge wire. I wounldn't want you to confuse the two. Good luck and tell me what you decide.
Sincerely,
Shawn Watson
http://monstercable.com/custom_inst...CI.asp?pin=1447
