Quote Originally Posted by pctower
Fine. But you fell way short with that advice. You failed to inform about the vagaries of sighetd listening to determine audible differences. It doesn't work too well.You left this out because you yourself don't know? Or, you may be worried about the truth?
Just as your absolutist advice to newcomers falls way short by failing to explain it is based solely on "not proven". I guess that makes two of you who may be worried about the truth.
Absolutist advice? What is this, Phil, argument by making up a phrase, attaching an adjective to a noun? It looks like another misrepresentation. We do not maintain the null hypothesis is proven, never have, and yet you continue to make the false allegation that we do. You imply that we do not want larger scale studies to increase reliability, to reduce the likelihood of Type II errors, which is false, and you know it. Of course, if one does not conclude the null is proven, then one avoids making Type II errors. None of this deters you, Phil, for you keep on making the same false allegations.
Oh, like SET amps? Passive preamps?
LOL.
You are at your finest when you're behaving in an arrogant, condescending manner. Is passive agressive behavior a component of the scientific method?
You are referring to Wrightstuff, of course! In any case, mtrycrafts manner is irrelevant to whether interconnects and speaker cables make an audible difference and under what conditions.
