It may not be your point, but it perfectly supports the observation of mine that you took exception to. At least Woodman acknowledges that his opinion is driven by theory, not direct experience.
Woodmans reply is not to the point either.
Let me lay it out then: As moderator, you should depart from of such statements that can be viewed as ad hominem attacks. If you cannot, maybe you should reconsider being in that position.
-Bruce
