Results 1 to 25 of 27
    Jul 2006
    Quote Originally Posted by Pogi
    By the way, I was thinking of selling my yamaha RX V457 and buying a second hand Rotel RA 01. What do you guys think? Will there be a big difference in sound quality?
    well,
    yeah,
    rotel sounds much warmer than yamaha, and the RA-01 is a real stereo amp, so,
    although, the rotel isn't really powerful, so maybe you'd be better off saving and buying a better amp later.
    Keep them spinning,
    Bert.
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    Jan 2007
    Thanks for the advice. But I don't think that power is really a factor cause the area is really small. My living room is just 12' x 14'. Anyway, I tried the Rotel on the Wharfedales... I didn't know it would make that much difference. The bass became softer, vocals were alive!, and everything just became clearer. It gave more life to the Wharfedales! I appreciated my speaker choice even more!
    I think I would get a 2 channel amp when I sell my Yamaha.
    Any other suggestions on 2 channel amps that I could check out? Please suggest amps that are on this price range only. I can't afford too expensive amps.
    Again, thanks for your posts. Appreciate it.
