denon's, but that might be a problem to get an integrated when you're in the USA, they only have the pma2000, the older version, and it's very expensive, but for the rest,
Nad (sounds warmer than rotel), cambridge audio, marantz, ...
what exactly is your price range?
Keep them spinning,
Bert.
Thanks for helping me out. I'm actually in Asia.My budget would be around $200. Will check out NAD, Denon and Marantz. I think we have that here. But I think we only have home theater amps for Marantz(will check). Which models would you suggest at my price range?
