go for the Monitor Audio if possible, they are the best in your list! also there are some better amps than Yamaha, try some British ones if you can. cables/interconnects to use - QED silver or Kimber 4TC are much better if you can afford them.
doesn't matter what music you listen to, it is possible to build a system that sounds good on all types of music.
