"I have found it to be a trivial matter to setup and use my two channel 11 band eq.. Trivial enough, in fact, that my 9 and 11 year old children can also use it.."
Apparantly that is why you get results that are so trivial that you prefer to bypass it. I think that proves my point. Even if you suspend your disbelief that this can actually be a useful tool in a fine home audio system, getting real benefit from it takes more than a trivial effort. Most people give up long before they even start down the right road so what you say is hardly surprising to me.
If you ever decide to make any serious attempt to use it. Why not first listen to a lot of unamplified live music, then set all of the controls for flat, and then adjusting only one or two controls very cautiously, see if you can get just a minor improvement for a start. Don't do anything else for weeks until you are convinced that the change is for the better not for the worse. Then satisfy yourself with just a small improvement each time taking days or weeks to decide if the last change was for the better or the worse. Reitterate this until you are just about nuts and you'll get some idea of why I say it is a long slow patient process. Any attempt to fix every problem at once is doomed.
Ummm...Skep? Ya gotta lighten up, dude..it was a joke..don't worry, I'll keep my day job..
Cheers, John
