I would never source a power amp through a conditioner, especially the 10 amp per monoblock VTL tube amps. With few very expensive exceptions (Nordost, Audience, Shunyata, etc.), they limit current and thus dynamic range. I run all my power amps and the speaker power supplies through JPS Labs, Harmonic Technology and some DIY after market cords. Result? Better bass punch and low level resolution through better RFI rejection. I run the sources through conditioners.
The usual canard is that after miles and miles of wire, how can the last three feet make any difference? The problem with that myopic view is that the cords represent the first three feet in an environment most likely polluted with any number of digital switching power supplies. There was an old TV repairman here by the name of Woodman who staunchly asserted that there was no possible way that any power cord could ever make a difference. Naturally, he had zero actual experience with any aftermarket cord and relied entirely upon his speculation and imagination. The concept of cords actually having active RFI filter networks and shielding was beyond his ability to comprehend. I can think of some others here today who will likely share that same view.
So are you recommending that I should not run my amp through the power console? Its only a Rotel RB 1080 @ 200 per channel. Would I benefit by going directly into the wall?
I have a Belkin power console PF31 and its very convenient. I hit one botton and everything turns on or off with the amp on a delay and I know I have some sorta protection.
frenchmon
