"We are greatly appreciative of Bruno's efforts in this article. However, I felt it important to mention that much of the focus of this article pertaining to microphonics and triboelectric effects is relative to how interconnects may interact when interfacing high gain low impedance drive to high impedance circuit terminations, such as the case with microphones and phono preamps. In reality the triboelectic effect rarely becomes a real world problem in consumer audio. Microphone applications must be considerate of these effects, especially since the cables attaching the microphones are often in motion caused by the singer and/or local mechanical vibrations which can induce noise into the system. In such instances there are specifically designed cables with dampening materials (usually cotton) to nullify this problem by acting like shock absorbers to reduce contact area as well as employing a different shield construction which is less prone to triboelectric noise."
I'll be sure to keep this in mind when running microphone cables. Oh wait, I already do!
What you have quoted is Gene DellaSala's comments on the article by Bruno Putzeys. How do you know Putzeys agrees with DellaSala's comments on his article?
