Quote Originally Posted by Beckman
Wouldn't $500 in room treatments produce better results than $500 in cables?
I found different benefits for each solution with my system. If one is forced to choose only one or the other, then I believe it boils down to preferences.
Better cables produced a blacker background resulting in higher resolution in my system, especially low level passages found in my classical favorites. The bass traps, room lenses, and sound panels primarily address bass node issues and control the reflectivity of my bipolar stats. Not to mention placing the speakers seven feet out from the back wall. Madonna's bass is cleaner and more extended. Voices are more focused.
Like musicoverall, I'm fortunate in that I utilize both. All of my treatments are DIY. I use 8 traps placed in the corners and the midpoints of the walls. Room lenses flank the speakers at the first reflection points and sound panels are found behind them. I'm still waiting for my mother -in-law's help for sewing the matching grey spandex for the traps.
