there was no bad connection for sure, im very carefull about thoughs things, every strand of the cable goes in as well, i make sure not to cut or severe any strand.
and all i can say is that distortion at high volumes is gone. its not something you can just believe. i have had people comment on it sounding better, "becuase i watch movies, and music really loud with friends" and they noticed the change as well, and they know nothing about audio stuff.
but like i said, "it probably doesnt count" it was really bad cable to start with, it was like commercial data transfer wire, that some neighbour gave us and said it was awsome stuff, but it wasnt......... i have my rears turned up to 14 feet away, when there really only 7, in order to make the level with the fronts, thats how much signal it loses from around 40 feet of this wire. and ive tested it, since i have a rear centre as well, and that is run with good wire, i plugged a speaker into that and set it for 7 feet and it works loud and clear.
