Results 1 to 25 of 68
    Suspended markw's Avatar
    Quote Originally Posted by uncooked
    i have to, i was using 14 gauge tin wrapped copper for my fronts, and i switched to 14 gauge copper, and it sounded like twice as good, all the highs were in the music, before it was all really deep and sounded muddy. but i have to admit it was really crappy wire to start with, so i dont know if it counts
    The only possible reason for something like this is that they were not connectecd correctly. If they were, this is patently untrue.
    On many ocasions I have been at people's houses and asked to comment on their systems etc. Generally during any kind of review I try to glance at the cabling. You would be amazed how often I find blackened copper ends held at best loosely into their sockets. As a matter of course I will snip off those blackened ends, expose some clean copper from under the sheath and properly tighten the connections.
    Sometimes this simple fix can provide discernable improvement in the sound - sometimes not (to the owner I mean).
    On other ocasions I have found cables worn, bent at right angles and even nailed to the wall (through the copper). I generally suggest replacement under these circumstances - unless there is sufficient wire to cut off the damaged sections.
    To say someone is lying when they find huge differences in cables is wrong - there can be many and various causes aside from any sonic benefits of one cable over another.
    MY favorite of all was a friend who bought a pair of Klipsch KLF 30's and was complaining of having no bass (each speaker has 2 12 inch woofers in a ported enclosure). when I went round I discovered the problem was the cable. He had only connected the upper connectors - the lower ones were not connected to anything (the little solid copper links usually supplied were MIA). I cut about 3 inches off each cable run and linked the 2 connectors together. Made quite a difference...
    well it is different now, they were connected properly for sure, and now that the new wire is on i can turn it up as loud as i want with no distortion, before the voices in movies would get really harsh, everybody would have a really bad lisp, every s was dragged out. now its perfect.
    What does your system consist of?
    The reason I ask this, and I doubt your claim, is that when cable differences do exist (and, yes, they possibly can) it takes a system of fairly high resoultion and even then, the differences are subtle at best and yhen heard only under fairly careful listening.
    Not to sound elitist. but somehow I don't think yoursystem has that resolving power. Mine doesn't and you can view it @ audioasylum under markw*.
    Now, here you are claiming a monumentous gain in quality? Sometimes we hear what we want to hear, not what is. If there was a change in sound, odds are it was a bad connection that was fixed when you changed cables.
    But to hang that change on cables? Nahhhh.
    I would have to agree.
    there was no bad connection for sure, im very carefull about thoughs things, every strand of the cable goes in as well, i make sure not to cut or severe any strand.
    and all i can say is that distortion at high volumes is gone. its not something you can just believe. i have had people comment on it sounding better, "becuase i watch movies, and music really loud with friends" and they noticed the change as well, and they know nothing about audio stuff.
    but like i said, "it probably doesnt count" it was really bad cable to start with, it was like commercial data transfer wire, that some neighbour gave us and said it was awsome stuff, but it wasnt......... i have my rears turned up to 14 feet away, when there really only 7, in order to make the level with the fronts, thats how much signal it loses from around 40 feet of this wire. and ive tested it, since i have a rear centre as well, and that is run with good wire, i plugged a speaker into that and set it for 7 feet and it works loud and clear.
    That harshness, etc.. sounds more like an amp on the verge of clipping.
    I am curious as to the physical differences in the old/new wires. What is the gauge of the two wires in question?
    Nobody has ever disputed that a wide disparity in wire gauge over a distance can cause a voltage drop, which is measurable and can, in some cases, be audiable.
    If that's the case, then there could be a reason for you having to drive the amp so hard as to strain it, which is what you seem to describe. Using a high gauge (thin) wire for a long run is a no no.
  1. The Great Cable Debate
    By happy ears in forum Cables
  2. Three Cables, Two Months, One Baby
    By Mwalsdor_cscc_edu in forum Cables
    Last Post: 12-03-2003, 07:12 AM
