Results 1 to 25 of 68
    Suspended markw's Avatar
    What does your system consist of?
    Quote Originally Posted by uncooked
    well it is different now, they were connected properly for sure, and now that the new wire is on i can turn it up as loud as i want with no distortion, before the voices in movies would get really harsh, everybody would have a really bad lisp, every s was dragged out. now its perfect.
    The reason I ask this, and I doubt your claim, is that when cable differences do exist (and, yes, they possibly can) it takes a system of fairly high resoultion and even then, the differences are subtle at best and yhen heard only under fairly careful listening.
    Not to sound elitist. but somehow I don't think yoursystem has that resolving power. Mine doesn't and you can view it @ audioasylum under markw*.
    Now, here you are claiming a monumentous gain in quality? Sometimes we hear what we want to hear, not what is. If there was a change in sound, odds are it was a bad connection that was fixed when you changed cables.
    But to hang that change on cables? Nahhhh.
    I would have to agree.
    there was no bad connection for sure, im very carefull about thoughs things, every strand of the cable goes in as well, i make sure not to cut or severe any strand.
    and all i can say is that distortion at high volumes is gone. its not something you can just believe. i have had people comment on it sounding better, "becuase i watch movies, and music really loud with friends" and they noticed the change as well, and they know nothing about audio stuff.
    but like i said, "it probably doesnt count" it was really bad cable to start with, it was like commercial data transfer wire, that some neighbour gave us and said it was awsome stuff, but it wasnt......... i have my rears turned up to 14 feet away, when there really only 7, in order to make the level with the fronts, thats how much signal it loses from around 40 feet of this wire. and ive tested it, since i have a rear centre as well, and that is run with good wire, i plugged a speaker into that and set it for 7 feet and it works loud and clear.
    That harshness, etc.. sounds more like an amp on the verge of clipping.
    I am curious as to the physical differences in the old/new wires. What is the gauge of the two wires in question?
    Nobody has ever disputed that a wide disparity in wire gauge over a distance can cause a voltage drop, which is measurable and can, in some cases, be audiable.
    If that's the case, then there could be a reason for you having to drive the amp so hard as to strain it, which is what you seem to describe. Using a high gauge (thin) wire for a long run is a no no.
  1. The Great Cable Debate
    By happy ears in forum Cables
  2. Three Cables, Two Months, One Baby
    By Mwalsdor_cscc_edu in forum Cables
    Last Post: 12-03-2003, 07:12 AM
