but it's gonna be tough to finish because I'm sure your working and packing, etc. Wow, then you gotta set up the new household but it does give you an opportunity to redo the HT/living room layout. Of course then you gotta do the SPL calibration thing and all that good stuff. I wish you luck but I know that your gonna be one tired camper after moving.
I'm cutting and glueing the grills this Sunday (almost forgot about them bad boys). Then I need to drill the guide holes for them before I continue priming, sanding, painting, etc. Ed didn't leave us a lot of room on the woofer edges for grills (especiall since I used a 3/8" roundover on all edges. That leaves about 5/8" of an inch so I'm planning on making them 1/2" wide and 1/4" thick using those small grill guides from PE that just happend to be 1/4" long. Using red oak so hopefully they will be strong enough because they are pretty thin. Well, I better quit messing around here and get back to work. Talk to ya later. Have a good one, Paul.
