(Please bear with me as I know little about speakers and even less about woodworking.)
Quote Originally Posted by EFE Speakers
Outside dimensions are 13" high x 8 3/4" wide x 9 1/4" deep
Inside dimensions are 11 1/2 high x 7 3/8 wide x 7 3/4 deep
I gather that these plans call for 3/4" thick material such as MDF for all six sides? If so, isn't one of the width measurements off by 1/8"? Which one is correct? (This is nitpicky, but if I'm going to do it, I might as well do it exactly right.)
Port size is 2" Dia. (ID) x 6" deep from rear surface.
Rear Port hole is centered (widthwise) and 3" from top to center of port.
I don't understand this bit. What is a port? What is "(ID)"? How can something be 6" deep from the (inner? outer?) rear surface--won't it be right in the inner cavity? And is a "rear port hole" simply---from a woodworking perspective, anyway---a hole in the rear panel?
Speaker input terminal hole is 1 15/16" Dia. It is countersunk 3/16" deep x 3" Dia.
A Google search tells me that countersinking is like making a "starter hole" for screws, but that doesn't seem to be the case here. Should I just think of it as a cylindrical hole that doesn't go all the way through? I suppose then that the countersink "hole" should be on the outside?
Seems like one can choose to countersink the tweeter and woofer holes. Will these again be from the outside? Are there any advantages or disadvantages apart from aesthetic ones?
poneal, do you find Titebond glue alone strong enough, or did you use L-shaped brackets on the inside too?
And thanks to Jim Clark for pointing the AR.com DIYs out to me.
Peter
