I'm going for approx 35.5" high. I have a low couch and that height would put the tweeters at my ear level (which is usually recommended for floorstanders). eg. the top part of the cabinet will look exactly like a bookshelf AR.com DIY eg. 3" tweeter centre from top of cabinet, woofer approx 6mm from tweeter etc...
What I find hilarious is most manufacturers will make the lower end towers "shorter" to make their models through the range look bigger and justify the increase in price. If I made speakers......
Cheers,
David.
