A couple of points here. The NAD integrated sounds good for the money, but it's weakness or performance bottleneck is the preamp section, the amp section is very good indeed. I have added a Rotel preamp to my NAD integrated and the difference is astounding. The Rotel preamp powersupply & caps are the size you'd see in a receiver or small amp! Trust me, I almost didn't believe it till I tried, but these guys who preach separates and good preamps know what they are talking about. A very high level of transparency is there now. My soundstage got larger, and most of all imaging got sooo much more defined and solid (placing all the instruments and vocals in space). I suggest for your upgrade forget about the C372 & C270, and go with separates. I say get a preamp now...your C370 is the C270 essentially, so stick with that for now. You can hook the preamp to the main in jacks on the back...one of the great features of NAD integrateds. You can then enjoy that till you are ready to upgrade again, at which point you may look at amps like Bryston or PS Audio, etc. to replace the NAD, because it will take a good one to really beat the C370. You may want to shop Ebay & www.audiogon.com for good deals, and by no means do you have to stick with NAD. In fact I have not heard many good things (or bad things) about their preamps. There are lots of great preamps out there that will do amazing things for that amp. Do plenty of research or dealer testing so you can see that amplifiers potential...
best of luck to you
