Results 1 to 25 of 58
    Feb 2004
    Chicagoland area (Streamwood, IL)
    From what I've heard the PS80 is pretty sensitive to placement. I've been remodeling for a little while so my HT equipment has been all over. Mine only sounds a little boomy at very high volumes with songs or movies that have loser bass (i.e some R&B or rap).
    Remember that this is an entry level sub, so sometimes it's difficult to compare it to others. Make sure you compare apples to apples. Some reviews are negative because it doesn't sound like this $500 or $600 sub. It shouldn't sound like a $500 or $600 because it's only a $300 sub!!
    Are you able to demo one at home? If I were to do it again, I would demo a PS80 and some other subs at home before making a final decision. I don't say this because I think it's not performing well; I say this before I want to ensure I'm making the best decision possible. It's also difficult to listen in the retail "showroom" because the odds are the room size and set up isn't exactly as yours at home.
    In addition, I didn't have anything to compare the PS80 to. I only had 2 channel before the sub.
    Good luck.
    Feb 2004
    Take a look at a SVS 25-31pci. It has the kind of bass you are looking for. You'll have to keep it low...but you'll have that with whatever sub you look at, unless it's not very good.
    Jul 2004
    Quote Originally Posted by goatspeed
    Thanks all for the info on the subs, PS80 sounds good but like they say its a $300 sub, that is why I was somewhat drawn towards the small M&K's very tight and deep, however some say overpriced. Goat you are absolutely right I am going to keep the volume low around 8 o'clock or so- I just want to add a little low base presence without breaking the bank or blowing the walls out. I looked for the above sub but could not find it on the web site. Anyone want to suggest a good sub that hits fast and tight and can be had for under $500 or so??? My main concern is that they can match the incredible tightness of the Focals.
    Feb 2004
    Here's a link: http://www.svsubwoofers.com/subs_pci_25-31.htm
    It's a little over your price range, but you can order it and try it knowing you can send it back within 45 days for a full refund. I have a house and a little larger room, I went with the 20-39pc+ and find it to be fast and accurate, sounding perfect with my new Monitor Audio setup.
    Jul 2004
    Thanks again.... Hey I recently stumbled across the Athena P2 subwoofer which has gotten excellent reviews- does anyone have any feedback on this before I order it?
    Jul 2004
    Goat I like the sounds of the SVS suggestion but I dont think I could get away with having a 30" tall 16" diameter black bass tube sticking up in my living room, though I appreciate the suggestion and mulled it over for quite sometime before reality hit me (wife factor)....
  1. Ground loop in subwoofer -- did my printer create this?
  2. Replies: 1
  3. Subwoofer & DSP
  4. Looking for a Subwoofer under $400
    By agidol in forum Speakers
  5. Do you know if this subwoofer is any good?
    By polo13 in forum Speakers
    Last Post: 12-13-2003, 12:43 PM
