Just don't get yourself in such a hurry that you end up with a room full of speakers and out of all of them 1 pair you really want to keep. I do believe that the Ushers are very good and you could get your money back out of them if you liked the proac better. But I would also hate for you to go ahead and order those speakers and then go this weekend and demo the Dyn's or Magi's and fall in love with one of them. The two speakers that would most likely work the best for me would be between the Dynaudio and the ushers because they are not bright. And are very good with all types of music and have less of a dynamic limitation of the magnepans which I am not downing since they are great for what they can do I just do not like speakers that big to have the bass limitations and dynamic limitations that they seem to have. Plus my listening room would be a tight fit with a pair of Magnepans and I don't think i would have room to let them do what they do best. that would be the main factor to look at if I was you when it comes to the magnepans. If your room is big enough and you have enough open area in that room for you to move them around and get them away from the back and side walls like I have heard they do need to get the best out of them. Dynaudio,Paradigm,usher and others are a little more open to placement and also are not as big and room imposing as the magnepans. But you might find that the magnepans give you exactly what you need and are willing to live with them being bigger and the placement demands. Any of the brands we have talked about are going to be vastly different form the B&W's from which you are used to. B&W's to me are great out of the gate but they get real fatiguing after around 30 minutes or so.
