Results 1 to 25 of 37
    The question is how can you judge "accuracy" in determining warm, cold or neutral?...
    Easy. Be involved at the recording venue at the time. I have had the good fortune to hear my local symphony record for Telarc on more than one occasion. I've spoken with the conductor and have some understanding of his goals.
    A flat frequency response is paramount IMHO...
    Except, of course when those measurements are made in an anechoic chamber which in no way resembles the environment in which the speakers are designed to work. A truly flat speaker under those circumstances will be intolerably bright.
    ...furthermore, that it is singly responsible for our perceptions of those qualities beyond the obvious timbral ones.
    Our experience sure renders us with very different opinions. I hear significant differences in transparency and imaging in speakers that I find significant.
    However, without the ability to control FR by placing "unwanted" devices in the signal path, many will spend too much time searching for their version of the Grail and too little time enjoying the music.
    Or "B", use various sorts of room treatments to solve the primary issues of room nodes. I continue to be amazed at how good many old recordings really are. Occasionally, I'll use the HF contour provided with my 'stats to tone down some really old recordings that are a bit raw.
    Nueva Jork
    Er...um..huh...
    Gee, I thought I said that...in the next paragraph.
    Quote Originally Posted by EStat
    Gee, I didn't think I HAD to say that...pretty much took THAT as a given...
    Gee, all I said was..." A flat frequency response is paramount IMHO...furthermore, that it is singly responsible for our perceptions of those qualities beyond the obvious timbral ones." I think the importance of FR re: other parameters is given short-shrift by many...
    Or "B", use various sorts of room treatments to solve the primary issues of room nodes...Occasionally, I'll use the HF contour provided with my 'stats to tone down some really old recordings that are a bit raw.
    Gee, I've done that too...except I call 'em "tone controls"...
    jimHJJ(...looks like we are in agreement...sorta'...)
    Ah, the rhetorical question.
    ...it is singly responsible...
    I simply disagree with the term "singly" as I find multiple answers.
    Indeed. I've always had speakers with such that eliminates the need for superfluous gain stages.
    Nueva Jork
    Oh. Lordy...
    Ah, the rhetorical answer!
    Dispersion characteristics don't necessarily have much to do with FR...or do they? Should have qualified the word "qualities" with the phrase "many of those"...I'll try to be more precise...
    Much akin to the old "tree falling in the empty forest" bit, if you use a tone control in the "cut" mode, is it still a gain stage? Is it a tone control? Is it bigger than a breadbox?
    jimHJJ(...let me whip out the old schematic and see how many more transistors are in the signal path...)
    All I'm saying is that FR alone (or singly if you please) does not a great speaker make. Witness the AR-LST. What a toad. But it looked great on paper! Or you can equalize any number of speakers to be flat, but not possess especially high resolution.
    From my perspective, if you are using an equalizer using any number of active devices with a stated output voltage, then the answer is yes. Most folks don't consider a resistor (either fixed or variable) and a cap like you find in a speaker crossover as a "gain stage".
    Nueva Jork
    Speaking of rhetorical...
    ..."Dispersion characteristics don't necessarily have much to do with FR...or do they?..."
    I said I'd try to be more precise. I remember them...although I don't recall their sound...Why were they toady? Resolution? That's an ambiguous term...resolving what exactly...image?...depth?...Did a flute sound like a flute?...a banjo like a banjo? I rarely see if I can play pin-the-tail on the oboeist...I listen to music...sonic holography is secondary...I rarely get to sit in the "sweet-spot"...
    No, I guess that's just a load...
    jimHJJ(...or so it would seem...)
    LIkewise, it's been a while since I last heard them. I used the term that the salesperson gave me at the time. Dull and uninvolving is my recollection. If AR were still around, perhaps you could ask them why they canned the LST series.
    One of the delights of getting a new component for me is rediscovering old musical favorites. Since I acquired new speakers last month, I have been hearing deeper into all sorts of recordings that I have heard countless times over long periods of time. From 60s Astrud Gilberto to current Higdon, I hear new details in the music. Improved vocal articulation. Hearing the harp distinctly for the first time in a piece of music. More texture to the rosiny growl of strings. The sound of a twelve string guitar's body. Rendering spatial cues more evident.
    Do you have a high def TV? If you do, then you know what I mean.
    AR,PL,Devotee' Registered Member
    Aug 2005
    ny
    Dear Sir, I resent your comment that the AR-LST is a 'toad'. I run 4 stacked and they're probably the best sounding speakers going!
    Quote Originally Posted by frankmarsi
    Whoa, I had forgotten this thread from seven months ago.
    Actually, that was the term the salesperson at Hi-Fi Buys who sold them used. He was not very impressed with them.
    Double LSTs. What amp(s) do you use with them?
  1. Paradigm Studio 20 vs B&W 602 S3
    By Yeti2003 in forum Speakers
    Last Post: 08-22-2005, 11:04 AM
  2. The Nuance thread
    By Mike H in forum Speakers
  3. Looking for a certain type of speaker
    By nahmed in forum Speakers
    Last Post: 08-31-2004, 10:14 AM
