Results 1 to 6 of 6
    The newer Yamaha receivers sound a bit better than mine from what I've heard. Maybe I could keep the receiver and just add better amplification?
    Well, don't believe everything you hear
    I seriously doubt you have a receiver problem. How large is your room? Which surround speakers? Can you do rear center with your setup now?
    Did you level match all the speakers in the new setup?
    mtrycrafts
    Using Paradigm Reference Studio 20's for surround. I don't have a problem with my receiver, just wondering if I can upgrade to something that's better. It's the oldest piece in my setup. It's a DTS decoding 5.1 receiver. All the speakers are level matched (well, according to my SPL meter, however good that is). I'm sure I could better match my sub to my speakers but it's close enough for now. Bass isn't the problem. Just wondering what I can do.
    Is there anything you are dissatisfied with your setup? If not, I don't see any benefit to upgrading.
    mtrycrafts
  1. BUYING A New AV Receiver? Let me help and so can you!!
  2. is this receiver underpowered?!!!.....suggestions...
    By CyberStoic in forum General Audio
    Last Post: 03-12-2004, 07:51 PM
  3. Cheap receiver + power amp or expensive receiver?
    By kexodusc in forum Amps/Preamps
    Last Post: 03-08-2004, 10:57 AM
  4. Lost surround setting-Frequent power failure
    By bennie25 in forum Home Theater/Video
    Last Post: 12-08-2003, 07:09 PM
