• 03-11-2004, 03:35 PM
    kexodusc
    Receiver and power amp or bigger receiver?
    I'm currently looking at two options for upgrading my receiver. First, I could buy the Yamaha RX-V640 and used amplifer (probably arcam, adcom or rotel) to power my main speakers for stereo playback and lighten the burden on the receiver for movies.
    Or I can buy an RX-V1400 that has a bigger power supply and more juice, as well as a few interesting but not essential features. What would you do?
    Any advantages to using the power amp instead of the receiver or am I better off with investing in a larger receiver?
  • 03-11-2004, 03:51 PM
    markw
    Is your current receiver missing any vital features you can't live without? Is it so outdated that it screams for replacment?
  • 03-11-2004, 04:01 PM
    kexodusc
    Yes, I've moved into significantly larger room. My current Yammie RX-V795a is wonderful receiver and I've been very happy with it, but unfortunately I feel there is a large gap in the surround environment that might better be filled by a 6 or 7 channel receiver. I think 6 is probably sufficient. I'd be open to any suggestions on how to best improve my system. Currently I have two Studio 40's, two Studio 20's and a Studio center channel from Paradigm. I like them very much and don't think I can afford to upgrade speakers again anytime soon. I have a decent sub too. The newer Yamaha receivers sound a bit better than mine from what I've heard. Maybe I could keep the receiver and just add better amplification?
  • 03-11-2004, 05:54 PM
    mtrycraft
    Well, don't believe everything you hear :)
    I seriously doubt you have a receiver problem. How large is your room? Which surround speakers? Can you do rear center with your setup now?
    Did you level match all the speakers in the new setup?
  • 03-11-2004, 06:10 PM
    kexodusc
    Using Paradigm Reference Studio 20's for surround. I don't have a problem with my receiver, just wondering if I can upgrade to something that's better. It's the oldest piece in my setup. It's a DTS decoding 5.1 receiver. All the speakers are level matched (well, according to my SPL meter, however good that is). I'm sure I could better match my sub to my speakers but it's close enough for now. Bass isn't the problem. Just wondering what I can do.
  • 03-11-2004, 07:32 PM
    mtrycraft
    Is there anything you are dissatisfied with your setup? If not, I don't see any benefit to upgrading.
