Results 1 to 25 of 89
    Jan 2013
    I do not really know anything about amps. Plus, I like to have the possibility of upgrading my system down the road.
    Suspended markw's Avatar
    Quote Originally Posted by TheReturnOfJj View Post
    Now would be a very good time to learn, what with all this good advice being thrown at you.
    And you think other units will be less complex?
    Jan 2013
    Like I said I don't know. And yeah, it is greatly appreciated.
    Did you get the problem solved?
    Jan 2013
    Not really, I am considering trying the speakers on a different receiver. To see if there is something wrong with my equipment. I do appreciate all the help though.
    Jul 2002
    May I suggest that your expectation of bass quantity may be out of line with what the speakers can actually reproduce This speaker is -6 at 38hz, and -10 at 32hz which means the output of this speaker is falling quickly below 40hz. If you have them in a medium to large size room(or open space), the "knee" of the roll off would be much higher, and the falling off much faster as well.
    If you want more bass, perhaps a subwoofer would be in order here. You could go back to the 80hz crossover, and potentially have more bass below that frequency. You could also set up the main speakers for best imaging, and the subwoofer for the best bass.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Apr 2002
    Illinois
    On your remote there is a button that say's "Pure Direct". This sends everything to your front speakers bypassing all the other circuitry, including subs or any other speakers you have. This is strictly for 2 channel. In essence, your receiver becomes an integrated 2 channel amp.
    If this still doesn't do it for you, I might suggest a sub running off of your Left and Right Front Pre outs. (This is for "Pure Direct" mode only) Do not use the Sub Pre Outs in this configuration. If you do, switching to "Pure Direct" will cut the sub out of the circuit.
    Your other option with a sub, is to connect the Sub to the Sub Pre Outs and select the "Straight" button on your remote. This mode allows access to speaker configuration and tone controls, which you may have to adjust. The advantage of this configuration is that it works equally well for surround when you get your other speakers.
    I hope this helps.
