Results 1 to 25 of 89
    Jan 2013
    Like I said I don't know. And yeah, it is greatly appreciated.
    Did you get the problem solved?
    Jan 2013
    Not really, I am considering trying the speakers on a different receiver. To see if there is something wrong with my equipment. I do appreciate all the help though.
    Jul 2002
    Quote Originally Posted by TheReturnOfJj View Post
    May I suggest that your expectation of bass quantity may be out of line with what the speakers can actually reproduce This speaker is -6 at 38hz, and -10 at 32hz which means the output of this speaker is falling quickly below 40hz. If you have them in a medium to large size room(or open space), the "knee" of the roll off would be much higher, and the falling off much faster as well.
    If you want more bass, perhaps a subwoofer would be in order here. You could go back to the 80hz crossover, and potentially have more bass below that frequency. You could also set up the main speakers for best imaging, and the subwoofer for the best bass.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Apr 2002
    Illinois
    On your remote there is a button that say's "Pure Direct". This sends everything to your front speakers bypassing all the other circuitry, including subs or any other speakers you have. This is strictly for 2 channel. In essence, your receiver becomes an integrated 2 channel amp.
    If this still doesn't do it for you, I might suggest a sub running off of your Left and Right Front Pre outs. (This is for "Pure Direct" mode only) Do not use the Sub Pre Outs in this configuration. If you do, switching to "Pure Direct" will cut the sub out of the circuit.
    Your other option with a sub, is to connect the Sub to the Sub Pre Outs and select the "Straight" button on your remote. This mode allows access to speaker configuration and tone controls, which you may have to adjust. The advantage of this configuration is that it works equally well for surround when you get your other speakers.
    I hope this helps.
    Jul 2002
    Setting the mains to full range through bass management, and going pure direct will accomplish exactly the same thing - it will send a full range unfiltered signal to the main speakers.
    The OP ran Yamaha's auto equalization program, and that will benefit the overall sound of the system even if it is just two channel. If you use pure direct, that equalization will be defeated, and the OP will hear a less refined sound. While the auto EQ is not the best, it is better than nothing at all.
    If you are going to use a sub, it is much more simple and easy to use the sub out or LFE out with bass management controlling the crossover point. Running a sub off the pre outs of the L/R mains(and old school two channel mentality) is overly complicated, and not necessary at all. Going this direction causes you to lose the precise high/low pass filters in the receiver which helps subwoofer to main speaker integration. Why make the setup more complicated than necessary, and still not get the best sound?
    Sir Terrence
    Oppo BDP-103D
    Those PSB GB Speakers need time to break in. I would run them continuously for 8-12 hours a day for about a week and let the woofers break in. They are not going to give you deep bass. What they will give you is nice tight mid bass. Also, the GB's should have bass ports, make sure that the ports do not have plugs in them. Many speakers with Ports including some PSB models come with foam port plugs that you can use to tighten up the bass but they also decrease the bass. Removing the plugs will give you more prominent bass.
    If you have all the settings correct with the Onkyo receiver, it could be that the receiver just does not put out much bass or it could be your music source such as your CD, DVD player, computer or mp3 player. Also try speaker placement. Moving them to the corners of the room will help with bass.
    Apr 2002
    Illinois
    @ TheReturn0: In response to T's suggestion...
    If you're just interested in 2 channel audio, then using the "Pure Direct" button and the L/R Pre-out for a sub, is the much simpler way to go (one button - 2 wires - no menu adjustments). Although I would suggest a sub with a sharp crossover slope. Many of the cheaper subs have a gradual slope and that makes it hard to integrate with your mains. An 18db slope should work well. Stay away from subs with a 6db slope.
    If you are running your main speakers full range (Large), there is very little to gain by letting your receiver handle the bass. In fact, it might even make it worse since the sub's crossover point (with the control on the sub) can be more finely adjusted compared to what a receiver usually allows you to do. The only other thing is that going through the receivers circuitry you need to set your speakers up correctly. There is a slight learning curve here, but once you got it, you got it. The advantage of using the receivers circuitry for bass management is that it also allows you to use the tone controls. I should mention too that I have a Yamaha and while its auto adjust works well enough, I tend to adjust the EQ by hand for my preference.
    Either setup will work well enough and we are splitting hairs on this issue.
    Using the receiver to handle bass and setting your mains to "small" will set the crossover for both the sub and the mains, which is what T is speaking about. Whether it sounds better that way is a determination that only you can make. There is an added advantage of doing it this way and that is bass is removed from the mains allowing them to play a little louder, or lowering the amount of power the receiver needs to feed them during normal play.
    With one set of speakers I have, I set the mains to small and used the receivers circuitry to split the bass. With the speakers I am using currently, I run them full range (large).
    The bottom line is, what sounds the best to you...
    We keep talking about a sub that you don't have. Without the sub gives you two choices for the present configuration. Run the receiver in "Pure Direct" mode or in "Straight" (On your remote) mode which allows you to use your tone controls. There are other options, but you can look into those later. I think "Straight" just bypasses your DSP effects.
    As for your setup, go into your menu (if you haven' already done so) and shut off all of your speakers (including sub) except the mains (front). Then set the Front speakers to large. I assume you've already done this. Adjust your EQ (if you want) and you should be finished. There are other adjustments for movies, but this is all you need for music.
    I noticed that your EQ is parametric... Great! If you already have everything set up and you're still not happy with the sound, try adjusting the EQ manually. This should really help.
    There are many ways to do the same thing or variations, so there are will be omissions in what I've written. Otherwise, it would be confusing.
    Good luck!
    BTW, The only reason I brought this up in reference to T's suggestion is that there are many ways to skin a cat and many times the results are different. You're the boss here and only you can decide what works best for you.
    I have a surround system set up one way. My 2 channel system is set up another way.
