Quote Originally Posted by pomko
Ahh, ok I see what you are saying. The speakers are in the away from the corners and are about 3 feet apart from each other and I sit about 6 feet away from them, they are maybe 2" away from the rear wall. My room has thick carpet and 2 sofas. It is about 14' by 10'. I will rearange the room tommarow so that I sit farther away from the speakers because I feel as if they are too close anyways and move them around to see what kind of difference that makes. Thanks for the advice and I'll keep you posted.
Mike makes some good points. Before you start moving a lot of furniture around, try moving the speakers. Small movements can sometimes make big differences. You mentioned that your speakers are about 3 feet apart. You might try moving them a little farther apart. Maybe 6 feet apart or so. I am pretty sure those 100s are front ported and if so your bass might be overlapping and cancelling each other out. Not really sure about this, but it might be an issue. Easy to test though.
Good luck and let us know the results.
JSE
