Results 1 to 17 of 17
    Well, the sound is hard to compare becasue I have to listen to them at different shops and both sound great. I haven't taken either of them home. I really dislike Orange displays so the asthetics for me go HK , OK then Yammy.
    Here is some specs on the 3 receivers for other comparisons (apologies for length) :
    HK AVR 630 -$750
    Audio/Video Receiver With Dolby Digital - DTS- Logic 7- VMAx and HDCD Decoding / 75 Watts per channel surround
    The Harman Kardon AVR-630 7.1 Channel Surround Receiver is a powerhouse by anyone's definition -- a gentle giant, with incredible finesse when it comes to Audio fidelity.
    Dual core, 24-bit DSP processor with 32-Bit post processor
    Stereo Power -- 90 Watts x 2
    Multichannel Power -- 75 x 7
    0.07% Total Harmonic Distortion ( THD )
    6.1 / 7.1 Channel Capability -- 7 amplifier Channels -- 7.1 preamp outputs
    Frequency Response: 10Hz - 130kHz
    Multi-Room / Multi-Source
    Surround Back amplifiers assignable to Second Zone
    Integrated surround technologies: Dolby Digital, Dolby Digital EX, Dolby Pro Logic II, DTS 5.1, DTS-ES 6.1 Discrete and Matrix, DTS 96/24, DTS Neo:6, Logic 7, 96kHz capability
    VMax
    Dolby Virtual Speaker
    Headphone Modes: VMax, Dolby Headphone
    AM - FM Tuner
    Coaxial & Optical Inputs / Outputs
    S-Video Inputs / Outputs
    Subwoofer Preamplifier
    2-Line LCD Remote
    YAMAHA RX-V2400
    Massive power 7-channel discrete amplifier configuration (120Wx 7 RMS/FTC)
    Digital ToP-ART and High Current Amplification
    Direct Stereo mode for high quality 2-channel sound reproduction
    Accurate touch digitally regulated volume control governs all channels
    Finest parts used throughout for high sound quality
    Audio Delay for adjusting lip-sync
    New 32-bit Yamaha LSI (YSS-930) for CINEMA DSP processing
    Compatibility with latest movie sound formats including Dolby Digital EX, Dolby Pro Logic II, DTS-ES Discrete 6.1, DTS Neo:6 and DTS 96/24
    THX Select processing
    Component video up conversion:S-video/composite signal conversion to component video signal
    29 surround programs (49 variations) with SILENT CINEMA and Night Listening mode
    YPAO (Yamaha Parametric Room Acoustic Optimizer)
    Extensive inputs/outputs for A/V custom installation (Zone 2,Zone 3 and speaker A/B selection)
    9-channel speaker outputs:Automatic presence speaker or Zone 2 speaker selection .
    ONKYO TX-NR900 - $799
    110 watts x 7 channels into 8 ohms (20-20,000 Hz) at 0.08% THD
    THX Select certified
    THX Surround EX, Dolby Digital EX, DTS-ES, DTS 96/24 and Pro Logic II decoding
    DTS Neo:6 modes
    Net-Tune protocol
    Ethernet port
    MP3, WMA, and WAV decoding
    30 Internet radio station presets
    dual-room/dual-source A/V output (powered and preamp-level stereo audio and composite video output for 2nd room)
    Wide Range Amplifier Technology
    dual 32-bit processors
    pure audio mode
    composite-to-S-video conversion
    192kHz/24-bit DACs
    digital upsampling
    component video switching: 2 in, 1 out (60MHz bandwidth)
    digital inputs: 5 optical (including 1 front-panel), 3 coax
    2 optical digital outputs
    3 audio, 6 A/V (including 6 S-video, 1 front-panel, and one 7.1-channel) inputs
    7.1-channel preamp output
    on-screen display (requires TV with direct video input)
    backlit, learning/multibrand remote with macros
    12-volt trigger for Zone 2
    40 AM/FM presets
    17-1/8"W x 6-15/16"H x 18-11/16"D
    Power Specifications
    Power Output (8 ohm, 20 Hz-20 kHz, FTC)
    Front L/R 110 W/Ch
    Center 110 W
    Surround L/R 110 W/Ch
    Surround Back 110 W/Ch (L/R)
    Dynamic Power
    3 ohm (Front) 280 W/Ch
    4 ohm (Front) 220 W/Ch
    8 ohm (Front) 140 W/Ch
    Amplifier Design
    Identical Full-Bandwidth Channels 7
    Reduced NFB (Negative Feedback) Design
    WRAT (Wide Range Amplifier Technology)
    Non-Scaling Configuration
    DACs 192 kHz/24-Bit x 6 / 96 kHz/24-Bit x 2
    High Current Low Impedance Drive
    All Discrete Output Stage Amplifiers
    Optimum Gain Volume Circuitry Linear
    Digital Upsampling
    Home Theater Features
    THX Surround EX and THX Certified Select
    Extended Frequency Response (+ 1 dB, - 3 dB) 10 Hz-100 kHz
    DTS, DTS-ES Discrete/Matrix 6.1, DTS Neo:6
    Dolby Digital, Dolby Pro Logic II
    Dolby Digital EX
    A-Form Listening Mode Memory
    Composite to S-Video Conversion
    Multichannel Input 7.1
    CinemaFILTER
    Digital Soundfield Processing Modes 39
    Late Night Mode
    Color-Coded Speaker Terminals
    On-Screen Display
    Adjustable Digital Delay
    Crossover Adjustment
    Internet Features
    Net-Tune
    Ethernet
    Inputs
    Audio and AV Inputs 3/6
    HDTV-Ready Component Video Input/Output 2/1
    Front-Panel Video Input (with S-Video)
    S-Video Compatible Jacks Input/Output 6/3
    Digital Inputs 5 Optical (1 Front Panel), 3 Coaxial
    Digital Output 2 Optical
    Amp In
    RS-232 Control Port
    IR In/Out 1/1
    Pre Outs
    RI-Compatible Remote Control Prepro/Learning/Backlit
    Macro Function
    Absolute/Relative Volume Display
    Intelli Volume
    After doing months and months of research, I went with the AVR 630. I installed it this weekend and am in love with it so far.
    I went to many an audio shop and I found that it sounded the best with the speakers I wanted to buy (Canton CD Series). So far it sounds awesome. I'm only waiting for the release of the HK DVD31 to complete my setup.
    Good luck.
    Thanks for all of your insight. I am going to take another listen to the Avr630. I have added another to my comparison -- the Onkyo NR801. Trying to weigh the power and inputs of the NR900 vs. newer model and styling of the NR801.
  1. New HTIB: JVC vs Yamaha
    By Chrono in forum Home Theater/Video
    Last Post: 03-26-2011, 07:17 AM
  2. Denon 1602 vs. Yamaha RX-V440 ?
    By RandyClark in forum Home Theater/Video
    Last Post: 01-18-2005, 03:30 PM
  3. Yamaha Receiver VS Rotel preampTest...
    By 46minaudio in forum Home Theater/Video
    Last Post: 02-29-2004, 02:45 PM
  4. Onkyo Or Yamaha 2 Channel
    By Mark111867 in forum Amps/Preamps
    Last Post: 02-25-2004, 10:18 AM
  5. Problems with digital input to Yamaha RX-V1300
    By PmR in forum Home Theater/Video
    Last Post: 02-07-2004, 08:11 PM
