Thanks, bfalls, I'll keep an eye out for some RS speakers. I have a subwoofer already--in fact, it's one of the three pieces that I started with--a Klipsch LF-10 that I bought at the same time as the two RB-5's.
I guess what I keep thinking is that the RB-5 are so small that they might be better suited as rear channel speakers if I could find, say, a pair of RB-81 or RB-61 and use those in the front. I'm just concerned that they will be outclassed by a good pair of surrounds like the RS-52 or RS-42.
Also, do you think I should bi-wire the RB-5s if I keep them as fronts? Thanks again!
