Just FYI: The dimmer switch will interfere with your cabling, particularly the TV Cable and FM antenna (I had that problem). I don't know if fans will too, but they may have some impact too. I would use fans that are designed for this purpose in case they do need to be shielded in some way. Also use a good filtered power strip to plug everything into, or one of the affordable power centers from Panamax or Monster.
