Quote Originally Posted by Mike Anderson
Does anybody know of a way to insert this thing into a digital path using SPDIF connectors?
As far as I can tell, it only uses AESBU connectors for digital; is there an adapter or something I can use?
Use the AES connections on your transport and DAC or dont you have any? If not, then i would suggest the tape loop since the internal voltage is higher. Cheers
Flo
PS: 1.6's there yet?
