The Cabling problems
Choice of cables in an audio system has been very much pushed as a way to improve any system in the press during the last decades. No need to come back on the fact that cables sound different. But what seems less understood is that the sound of a cable is very dependent of the connected components. There is no such thing as the absolute best cable for any type of connection.
In a Goldmund system where the speed of the signal is mandatory and kept very high throughout, coaxial is the only reasonable solution. It is not only the best solution for digital cables, or for interconnect, but is also the best solution for speaker cables.
In addition to the speed that coaxial may help to maintain, the perfect shielding that the best ones may provide is mandatory to avoid oscillations.
Nordost is another cable manufacturer that is concerned about the speed of the cable. Early MIT and Monster cables used multiple bundles of different gauges also due to signal time. Audioquest used to state that 20 gauge solid core was the perfect size for the frequencies to travel at the same speed. Their speaker cables use multiple individually insulated solid core wires in their cables.
Interesting that I have never tried a coaxial cable. Wireworld and Crystal Cable are coax cables. Analysis Plus may also be considered since they have a center braid and an outer braid both conducting the signal.
I agree that there is no perfect cable for every application. Each designer focuses on what is important to them. Goertz cables are designed to match the loudspeakers impedance with the amp and reduce the EMF from travelling back from the speaker to the amp. Cables with networks can also be designed to block EMF from returning to the amp.
