I think you should take a look a the DR across the whole frequency spectrum for LPs, it is non linear, have a look, RIAA curve is a dB levels compensation curve, dB levels have to be lifted to compensate for its limited dynamic range in the bass regions.
The RIAA curve is set up to allow the cutting stylus to maximize the amount of music on a side. In doing so, the designers of the system boosted the trble and lowered the level of the bass. This minimized the power that the cutting head would need, limited the groove pitch cut into the record and maximized the time of each side.
To my knowledge, the RIAA curve was not meant to limit the dynamic range of the album, as the inverse curve in phono pre-amps is just that and if properly done should lead to "flat" frequency response and whatever DR the engineer put on the tape, in theory.
However, as a transducer system the cartridge will run into grooves that cannot be tracked i.e. Tealrc's "1812 Overture." A problem CD's don't have.
