Quote Originally Posted by cam
Hey ed/hersh/gein, one thing that I have found out that makes a dramatic improvement in your system that I thought I would share with you and your daddy Jacko, hook up your entire system to the lower plug in of your receptacle. That's where all the power is because electricity is so heavy that it produces more power to the lower plug in. If you use the upper plug in with that denon 3801 then you would be lucky if you got 8 watts x 7 all channels driven, while the lower plug in will give you about 575 watts x 7 all channels driven. Trust me, this is totaly true. Tell as many people as you can. Now get to it.
Good advice cam, but if he really wants to minimize the crosstalk and maximize performance, he should plug the receiver in to its own auxiliary outlets and run it in passive mode. The 3801 has 480 + watt power supply, more than enough to run the receiver...
