Point-Counterpoint. Cables have their own electrical characteristics and those characteristics can work well with the components they are linking together or degrade the sound because of mismatched characteristics. Cables at the midrange price range can be a cost effective way to achieve synergy in your system.
Cables are a component in your system that are probably the most trouble free. They have nothing to break down or wear out. I did recently pull a banana plug from a speaker wire and you really do want to pull on the plug and not the wire.
Talk to your local dealer and ask if he has any wires for an at home trial. Until you try different style of cables it is hard to tell if they are a positive or negative.
Like many things in life some are more able to hear differences in cables. Differences in cables may be more noticeable in two channel systems than multiple speaker processed systems. When I add a new component I change cables to hear which sounds best.
My system is not finished until the cables have been selected.
